Results 1 to 8 of 8
Thread: having issues
09-03-2015, 06:07 PM #1
- Aug 2015
- 12
having issues
this was printed with skeinforge
setting set at
15% infill
.25 layer height
2 shells
40 feedrate
60 travel
195 temp....
I am super new to 3d printing and have in total 25 hours experience any advice would be great!
09-04-2015, 02:27 AM #2
Not enough information:
- What material?
- HBP temp?
- Did you calibrate your extruder?
- What printer?
09-08-2015, 03:47 PM #3
- 462
Looks like you're over extruding. Have you calibrated the machine yet? http://reprap.org/wiki/Calibration
09-08-2015, 08:03 PM #4
Looks like you used too much plastic, have you measured your filament diameter?
09-09-2015, 02:07 AM #5
- Sep 2015
first ABS layer sticks at base plat (abs)
I have a problem. the printer at my work ( 250 Fortus mc ), is very good and accurate , only the first layer of abs is far too fixed on the abs plate (base plate (also abs )) .
I have ordered a super glue for bonding to take place only with the adhesive.
Do you may have a different solution to this problem?
print 4.JPGprint 2.jpgprint 1.jpgLast edited by Vink_Kunststoffen; 09-09-2015 at 02:33 AM.
09-09-2015, 02:14 AM #6
- Burnley, UK
- 1,662
How are you pulling things off the plate? You should do it by twisting the plate not trying to pull the printed item off.
09-09-2015, 02:27 AM #7
- Sep 2015
We do twist the printed items of the plate, by bend the abs support plate. Whereby the printed items break. but the fist layer stil does stick too the abs plate.
09-09-2015, 04:28 AM #8
- Burnley, UK
- 1,662
The first few layers are the raft anyway and they do not really have to come off the plate when the item does.
It is a strange problem that I have never seen before. I wonder if your plate is too high because the levelling probe is worn. Are you using Stratasys plastic?
