Thread: Colander
08-20-2015, 03:56 PM #1
- Feb 2015
- 29
Colander
My largest print to date, this colander should be usable for most any kind of fruit or vegetable washing or counter storage.
The print took almost 24 hours with a layer height of 0.200 mm. I sliced it with Simplify3D.
The STL file is available here:
https://pinshape.com/items/8191-3d-printed-colander2
or here:
http://www.thingiverse.com/thing:976922
08-21-2015, 05:48 AM #2
holes are pretty big - lots of stuff will just fall out :-)
peas, beans, small pasta, long thin pasta etc.
24 hours !
Okay let's see how fast i could actually print it :-)
okay yeah that's pretty big - had to shrink it down slightly to fit my printer.
So a 6 inch tall one at 0.4 layer height I could knock out in under 6 hours. Looked like yours was nearer 8 inches.
If you set layer height to 0.4 s3d says the ratio is wrong - ignore that and it prints perfectly anyway. Well it does on mine.
But defintiely more a waste paper basket than a colander.
For a colander you need small holes and mostly just in the base. It's only water you want to let out :-)Last edited by curious aardvark; 08-21-2015 at 05:59 AM.
08-21-2015, 11:14 AM #3
- Feb 2015
- 29
Thanks for the feedback I see your point. Maybe I should have called it something else. I was thinking about things like grapes or mushrooms. But you are correct about the other things - beans for instance would not be a good match.
I could put holes in the bottom, but my thought was that would tend to weaken the whole structure. I printed it with 20% infill; maybe I should consider 100% with holes on the bottom.
I have pretty much defaulted on 0.200 mm for layer height and I really didn't even think about that when I made this part. Since it has fairly gently curves I can understand why a larger value would probably work OK. I'm trying 0.300 on a new part I'm printing now with somewhat more curvature, so we'll see how that goes.
