Results 1 to 10 of 4110
02-04-2017, 06:11 AM #1
02-04-2017, 06:57 AM #2
- Dec 2016
I've been using borosilicate glass for a couple of weeks now. I started with Aquanet just as others have. I found it messy and sticking too well with ABS even when cooled down. I've gone back to the standard glue stick. This is working great for me. Clean up is a breeze with soap and water after 2-4 prints. BTW, I use one large binder clip with corner clips. The top "handle" of the binder clip is bent down to provide clearance from the stepper belt.
02-04-2017, 01:37 PM #3
- Sep 2016
- 80
I ordered 3/16ths, since that was recommended.
02-04-2017, 11:04 PM #4
I've heard of the chunking issue before and it has happened to one of my pieces before. I just use the other side and has been good since. You can try to call McMaster if you got it from them. Some have said they will replace the glass. I guess they can have a defect and chunk out on occasion. Try not to lift straight up when removing an object. ABS if done right will auto release when fully cooled. Don't over do it with the "Stick Um" stuff or what ever you use.
02-07-2017, 12:28 PM #5
- May 2016
- Annapolis, MD
- 523
I use 1/4" boro from McMaster as well. Had a small chunk of the glass come out with an ABS print, but I think I may have been too rough with it when removing the print. I flipped the glass over and have intentionally been more gentle. That was about 6 months ago and I've not repeated the problem.
