Results 1 to 10 of 35
  1. #1
    Quote Originally Posted by Marm View Post
    Then your landline connection should have a static IP address set, you won't need to port forward. Just stream using VLC.
    The IP isn't static. I can confirm that.
  2. #2
    Engineer Marm's Avatar
    Sep 2014
    Add Marm on Thingiverse
    Quote Originally Posted by asteinmark View Post
    It should be "static" for the time the printer and camera are functioning. I have missed a lot of details in the thread, but if you're able to, just knowing the IP of the camera each time you run it, may be doable.
  3. #3
    Technician
    Nov 2014
    Here is what I do: https://plus.google.com/app/basic/st...a-5eae1b56e6ac
    It streams to a youtube live event. You can watch it from anywhere. No port forwarding needed. No static IP needed. Bandwidth is just your system uploading it once. Youtube handles multiplexing it out to anyone who may be watching.
    Technically this can be done with any computer and webcam, but a pi and pi cam is cheap.
    If you want to be able to start / cancel prints remotely too, load the same pi up with octoprint. You won't be able to view the video stream through octoprint while you are live streaming to youtube.
Tags for this Thread
