Results 1,831 to 1,840 of 4110
06-11-2016, 10:50 AM #1831
- Nov 2015
- 43
06-11-2016, 11:12 AM #1832
It's the little circuit board with a small heatsink on it.
If you pull the bottom off and look at the main board you will see 5 there. One for each stepper motor.
The firmware will rarely be the problem it's much more likely to be a hardware failure.
What does the display say or look like?
06-11-2016, 11:21 AM #1833
- Nov 2015
- 43
06-11-2016, 12:36 PM #1834
Qidi Techs don't respond well to firmware upgrades.
It may be possible using a USBASP programmer to reload the hex code back into the board.
I have done this on an older version of the Qidi. That thread is located here https://www.3dhubs.com/talk/thread/avatar-iv-qidi-tech
Be warned unless your good with this it's not for the faint of heart.
It may be easier to just order a new main board.
06-11-2016, 12:48 PM #1835
- Nov 2015
- 43
Yeah hence why I never attempted an upgrade. I wasn't even trying to upgrade this time but only reset the motherboard to default but somehow managed to brick it.
I'm actually reading that thread now, but I'm trying to use AVRDUDE over USB since I can connect via usb and don't have a programmer. Could you give any specific pointers on using AVRDUDE for this machine? I do have a qidi tech I.
06-11-2016, 01:17 PM #1836
DO have both parts of the programmer.
http://www.amazon.com/gp/product/B00...ilpage_o03_s02 withhttp://www.amazon.com/gp/product/B00...ilpage_o00_s00 10 to 6 pin adapter. They are both needed.
Just follow my instructions and get the Path right for your computer.Last edited by rcleav; 06-11-2016 at 01:55 PM.
06-11-2016, 03:26 PM #1837
- May 2016
- Annapolis, MD
- 523
Just got the Toshiba FlashAir SD card working with the QIDI and S3D. Now, in S3D when I click "Save Toolpaths to Disk" it stores the files directly into the FlashAir SD card that's plugged into the card slot in the QIDI. Talk about fast and easy. No more SD card shuffle!
The FlashAir card was ~$20 on Amazon. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Configuration was a bit of a pain, but a video that ServiceXP had made and posted on this website was a huge help. That video is in the "General 3D Printing Discussion", subtopic "Toshiba Flashair SD Card Mapped in Windows", thread post #57.
06-11-2016, 03:41 PM #1838
06-11-2016, 04:55 PM #1839
- Nov 2015
- 43
06-11-2016, 05:44 PM #1840
