Results 1 to 10 of 4110
04-17-2016, 09:25 PM #11
Na it isn't really as bad, but the mods I make to my printers take time. Direct wiring the build plate power (+) directly to the power supply is most important. Do the math on this. 24v / 2ohm build plate. that is 12 amps flowing through a plug that on its best day is rated for 7 amps.
I've been wanting to put the adjusters on the outside corners for many moons. I don't have time to make the mod on this printer, but I want to switch to 4mm bolts for the levelers. The holes are 4mm and just need to be slightly enlarged and countersunk to allow 4mm bolts.
