05-07-2014, 04:19 PM #1
Creaform Launches 2 New Go!SCAN 3D Scanners
The 3D scanning company Creaform has just announced the release of two new 3D scanners. The scanners include the Go!SCAN 20 and the Go!SCAN 50. Both scanners are extremely accurate and easy to use. A typical scan takes less than 5 minutes, and you can start scanning within two minutes of turning the devices on. Here are some general specs of each scanner
Go!SCAN 50:
Scanner Resolution: 0.500
Scanner Accuracy: 0.050 mm
Depth Field: 250 mm
Recommended Size of Scanned objects: 0.3 – 3 meters
Go!SCAN 20:
Scanner Resolution: 0.200
Scanner Accuracy: 0.100 mm
Depth Field: 100 mm
Recommended Size of Scanned objects: 0.05 – 0.5 meters
More details can be found at the article here:
http://3dprint.com/3358/goscan-50-goscan-20-creaform/
Here is a picture of the Go!SCAN 50:
05-07-2014, 04:34 PM #2
- Sweden
- 18
When we get to know the price picture it may be interesting to start a discussion about these scanners...
05-07-2014, 09:43 PM #3
- Apr 2014
- 228
I'm guessing several thousand dollars, if not tens of thousands of dollars.
05-08-2014, 01:06 AM #4
They'll be way over $10k if the first scanner is to go by.
08-14-2014, 03:21 AM #5
- Jul 2014
- UK
- 124
The website has a "get a quote" button which translates as don't bother unless you've just won the lottery !
08-14-2014, 03:27 AM #6
08-14-2014, 06:08 PM #7
I only played with this one a couple times. Last years model actually. Easy to use.
A mid range price point when compared to the FARO scanners.
Sort of similar to a Kinect / Skanect hardware, software combination in how the user interface looks and works.
Makes darn good, accurate models and then has an easy to use clean up software.
A good tool for a medium to large 3D business. A hobbyist will have a hard time justifying the cost.Last edited by Papa Steve; 08-14-2014 at 06:36 PM.
