Results 1 to 8 of 8
09-20-2016, 12:57 PM #1
- Dec 2015
- 9
Deep Z Axis Scar / Deformity in Prints - Possible Causes? See Picture
Hello,
Somehow I started getting this large scar/cavern in my prints and I wanted to ask what the possible causes are of something like this. The picture below is of a 20mm cube showing the scar on the top side of the pic and the other side is on the bottom which I guess printed okay. The Scars on on every print in the same spot. What types of issues could cause this?
09-20-2016, 01:47 PM #2
- Jun 2016
- Oklahoma
- 904
Are you indicating that the lower part of the print is ok but at a certain height then that deep groove starts to show? Or is the scar from the bottom to top of the print on just one side?
If so that may be a mechanical issue. I would look for something hanging up like a wire. Any recent changes to the gantry or extruders etc.?
09-20-2016, 02:15 PM #3
If you're using Makerware/Makerbot Desktop then it could be the seam i.e. the point where each begins and ends (which in Makerware/Makerbot Desktop is in exactly the same place leaving a witness each time). Give us a bit more info like slicer, material, speeds, etc
09-20-2016, 02:21 PM #4
- Dec 2015
- 9
It is from top to bottom on the one side.
I think it is mechanical as even though there wasn't any intentional changes I had the belts off as I cleaned out the printer, the bars and extruder. I lightly lubed the X Y Z bars and pillow bearings with a drop of oil each and reassembled. Somehow causing this, but I am not sure how yet. I verified screws seem good, belts seem good, operation seems as smooth as it has been before, so not sure were I caused this issue yet.
Thanks for your reply.
09-20-2016, 02:23 PM #5
- Dec 2015
- 9
I was currently using Matter Control even though I think I have most major slicers installed. I did not try another as I am under the impression it is a mechanical issue (see my last post as it happened after some disassembly, cleaning, and reassembly)
It was Matter Control, ABS, 40mm/sec
09-20-2016, 04:36 PM #6
- Jun 2016
- Oklahoma
- 904
09-20-2016, 10:53 PM #7
09-21-2016, 08:37 AM #8
print looks like it was extruded too hot, but that's just an observation, wouldn't cause that.
Can we just say that taking the belts of for no good reason, is a bad idea :-)
It's not something I ever plan to do unless one breaks.
