Results 3,171 to 3,180 of 4110
09-18-2016, 04:37 PM #3171
- May 2016
- Annapolis, MD
- 523
09-18-2016, 04:37 PM #3172Editor in Chief
Bitsonline
09-18-2016, 04:43 PM #3173
- Jun 2016
- Oklahoma
- 904
09-18-2016, 05:50 PM #3174
09-18-2016, 05:57 PM #3175
- Jun 2016
- Oklahoma
- 904
The negative restart starts to reduce the excess on the seam but has the unwanted side effect of under extrusion in other areas of the print especially short runs.
I will try again and I assume also the retraction speed you suggested?
Do you suggest outside-in or the opposite?
09-18-2016, 06:27 PM #3176
I always go inside out. A negative restart shouldn't cause underextrusion. Are you forcing retract every layer?
09-18-2016, 06:46 PM #3177
- May 2016
- Annapolis, MD
- 523
Yes, I am using this feed carriage in one of my extruders. http://www.thingiverse.com/thing:857200 Although I have not yet tried Ninjaflex filament in it.
09-18-2016, 07:00 PM #3178
09-18-2016, 07:06 PM #3179
- Jun 2016
- Oklahoma
- 904
09-18-2016, 07:14 PM #3180
From sailfish manual. I know it says 3mm but it does have effect on 1.75mm... Just not as much.
This is primarily meant for extruders that use 3 millimeter filament.This ensures that, throughout the entire print, the extruder’sstepper motor is kept engaged and does not allow the filament tocreep out. This is mostly a problem with extruders that accept 3millimeter filament, as larger filament generates more back pressure.Therefore, this option is intended to counteract the tendency offilament to back out of the extruder when the stepper motor istemporarily disabled, a command some slicerswill add to theprint command file (for instance, ReplicatorG). For Cupcakeprinters the default is on; for all other printers, the default isoff.
