Results 3,141 to 3,150 of 4110
09-17-2016, 08:34 PM #3141
- Feb 2016
- 360
Go to WalMart or Home Depot and get a can of Krylon Fusion. It has a very light adhesion promotor in it that works perfect on ABS, PLA, and PeTG. It is pretty cheap too, $4 a can. A real light coat of that stuff (Im talking light, just a bit more than a duster coat) and you can paint on it with ANYTHING....autobody paint, acrillic craft paint...anything.
Go one step further and get yourself some Elmers wood filler putty (the cheap indoor stuff will work just fine). Do a thin coat of that and a quick sanding with some high grit paper, then base coat of Fusion and watever ya want for topcoat.
End result is something you would never guess came out of a 3D printer.
09-17-2016, 09:01 PM #3142
- Jun 2016
- Oklahoma
- 904
Coming along! I would reduce bed temp after the first or second layer still looks like to hot. Maybe try reducing the bed temp and print a few layers and see how it sticks. Don't change anything but the temp. I did have to run a higher starter temp on the blue but wasn't using glue or anything.
Another thing for PLA I would suggest removing the clear sides, top and front. Get some airflow!
Keep at it!! Going good! It will start to come together. 1 tip, resist making to many changes at the same time. Make a change, test and see the result.
09-17-2016, 09:43 PM #3143
Thanks for the info and help.
I lowered the bed temp. I print PLA with the top and sides off.
It is sticking so far. Fingers crossed. Once I get this dialed in for PLA I will run one of those dual blower setups in PetG to help cool PLA better. The one that was posted here that sits behind the extruders looks perfect.
Editor in Chief
Bitsonline
09-17-2016, 09:54 PM #3144Editor in Chief
Bitsonline
09-17-2016, 11:00 PM #3145
- Feb 2016
- 360
Something worth mentioning....
They do make stuff (mainly for autobody stuff) that is just pure adhesion promotor in a spray can. DO NOT use this on prints. It will disfigure ABS and PLA very badly.
This is why I like the Fusion stuff, its got just enough promotor to make any paint stick, but not enough to adversly effect the plastic.
Also got to be really careful when using top/clear coat, as ALOT of those will be really aggressive and detramental to these plastics. There is a great one I found though, solid clearcoat, great gloss, and can spray it directly onto a print as its silicone based. Its also made by Krylon, just says 'low oder clear coat' on the can. Get it at a hobby shop (I get it from HobbyLobby, but any arts n crafts store should have it). Look for it in painting section, as its made to go over oil pantings and such.
09-17-2016, 11:10 PM #3146
- May 2016
- Annapolis, MD
- 523
I'm pretty sure that I am in the minority here, but when printing fine detail in ABS I use the blower. When I do not use the blower on ABS I often have issues with small overhangs turning upwards into the nozzle. When that happens, eventually the nozzle crashes into the part being printed and often detaches the part from the bed.
Does anyone else here run a blower with ABS?
09-18-2016, 12:08 AM #3147
09-18-2016, 12:09 AM #3148
09-18-2016, 12:21 AM #3149Editor in Chief
Bitsonline
09-18-2016, 12:23 AM #3150Editor in Chief
Bitsonline
