Results 3,131 to 3,140 of 4110
09-17-2016, 04:15 PM #3131Editor in Chief
Bitsonline
09-17-2016, 04:22 PM #3132
Supports were on by default I disabled it.
Where do I change from mm/minute to mm/second? I have looked but I must be missing it somewhere.
Retraction is 1600 mm/min up from 1200 mm/min.
You were correct filament was 1.72 so I adjusted to fit.
Been using glue. Maybe bumping bed temp to 80c would help.
Editor in Chief
Bitsonline
09-17-2016, 04:23 PM #3133
09-17-2016, 04:24 PM #3134
- Jun 2016
- Oklahoma
- 902
Nozzle may still be to far away. I am on glass so it may not be the same but I tend to level cold and just go for a little resistance with the paper figuring once heated it will take up a bit of it.
Also you can try slowing the first layer down a bunch.
What temp is the extruder at? Maybe up is by 10 if only for the first layer.
Is fan on for first layer? Turn off for first layer.
I did have some trouble getting the PLA to stick to the blue stuff at first. I was making a pretty squished layer to get it to stick.
Just thinking out loud.
09-17-2016, 04:24 PM #3135
09-17-2016, 04:25 PM #3136
09-17-2016, 04:26 PM #3137Editor in Chief
Bitsonline
09-17-2016, 06:42 PM #3138
09-17-2016, 07:35 PM #3139
- May 2016
- Annapolis, MD
- 523
And to top it off you're now using that higher priced Raptor stuff. Just a perfect storm there. Maybe Talon is right and there will be a pent-up demand hitting soon? I've tried using the Raptor again here and so far, no jams. (More salt over left shoulder and knocking on wood colored Formica.)
Pokemon Go crazy people around here are banging on the door for Bulbasaur, Squirtle and Charmander etc. Maybe there is some demand for them down your way... I just discovered that I can "paint" on PLA or ABS with metallic marker pens. It's solid color, goes on easy and once dry, stays there. I am using the pens for coloring eyes and toenails / claws etc. on Pokemon thingys.
09-17-2016, 08:23 PM #3140Editor in Chief
Bitsonline
Completely new to 3d printing and...
06-13-2025, 01:52 PM in General 3D Printing Discussion
