Results 3,091 to 3,100 of 4110
09-15-2016, 02:55 PM #3091
- Jun 2016
- Oklahoma
- 904
I got it. That makes sense. I forgot about limiting the layer height to a percent of the nozzle size.
So, if I were to do a .28 or .32 layer to be with the 40 micron deal I would want to make sure I was doing infill every layer but if I am doing a .16 (instead of .2) I can do infill every other layer and get better quality with reduced time?
I think I also want to do no more than a .32 layer with a .4 nozzle (80% of the nozzle)?
09-15-2016, 03:09 PM #3092
Right, I like to be at about 70% of the nozzle size but you can get up to 75% which is 300micron. But that is pushing the limits of a .4 nozzle. The 160micron shells and 320micron infills is a good setup for faster printing. On some objects, infill takes 3-4x as long as the shells, and it is something that you never see when the object is done. So speeding the infill process up helps a lot. If you are wanting to do .3 or .4 shells I would put on a .6mm nozzle. Actually the next step I like is 240micron shells with 480 micron infill, with a .6 nozzle. That gets shit done fast and still looks good. Spritz it with a little acetone afterward and good to go....
09-15-2016, 05:54 PM #3093
- Jun 2016
- Oklahoma
- 904
09-15-2016, 06:11 PM #3094
09-15-2016, 06:52 PM #3095
I am having a heck of a time with PLA/PHA from Meltink.
Here is my Benchy boat. The bed is level, clean, glue applied. It stuck for the first 40 mins and then came loose. On top of it weird parts of it were printing perfectly and others a mess. Anyone have any ideas? I used S3D for my setup.
Editor in Chief
Bitsonline
09-15-2016, 07:03 PM #3096
Crank down your extrusion multiplier to .9 if it is 1.00
09-15-2016, 07:08 PM #3097
I had done that already. I feel like I am missing something simple.
Editor in Chief
Bitsonline
09-15-2016, 07:23 PM #3098
- May 2016
- Annapolis, MD
- 523
09-15-2016, 07:28 PM #3099
09-15-2016, 07:41 PM #3100
Editor in Chief
Bitsonline
