Results 2,751 to 2,760 of 4110
08-11-2016, 08:29 AM #2751
- May 2016
- Annapolis, MD
- 523
The printer has no coherent "image" memory. It has mechanical linkages, hot and cold areas, differences in surface adhesion and alignment, but aside from resonance, inertia and whatever was left on the build surface it doesn't remember what it just did. It moves, it spits, it sucks, universe ends. No big picture.
If the build surface was uniformly prepped then it's got to be in the slicer.
08-11-2016, 08:38 AM #2752
I can only think it is left nozzle drag. He didn't say which nozzle was printing, but I would remove the left nozzle and see if that helps.
08-11-2016, 08:52 AM #2753
- Jun 2016
- Oklahoma
- 902
08-11-2016, 08:56 AM #2754
- Jun 2016
- Oklahoma
- 902
Interesting idea. On my original install of the new extruders the right one was a fraction lower and I shimmed it up. I did the same shim on this rebuild but maybe with the gantry and all having been completely out and reinstalled is now a tad lower than before. If printing with the left nozzle the right would be in a relative position for the actual opening in the part.
However I do not recall seeing any scarring on the part from nozzle drag and also, the part printing on the right (part on the left is in the pic) has the same formation and the right nozzle would be over empty bed.
Still an interesting theory. I will explore more tonight.
08-11-2016, 08:59 AM #2755
- May 2016
- Annapolis, MD
- 523
08-11-2016, 09:05 AM #2756
- May 2016
- Annapolis, MD
- 523
08-11-2016, 09:16 AM #2757
- Jun 2016
- Oklahoma
- 902
I don't know. I have not seen an issue like this before but I have only printed this part one at a time and this is the first time I have ever printed two together.
The machine was a little noisy, from bearings I suspect, reason I was asking about lube!
I am wondering with all of the moving and fiddling replacing the extruders if the belt didn't come loose or part way out of the holder. It moves very easily side to side where the ends attach to the carriage.
08-11-2016, 11:01 AM #2758
- May 2016
- 31
Just going to throw this out there: has anyone looked into fitting a laser cutting toolhead to their QIDI? It seems simple enough and I'm starting to look into what it would take to make this happen. I've seen some some ready made retrofit options (e.g. something called "el cheapo") but ironically I feel like a diy would be much cheaper.
Off the top of my head I see these things being on the BOM:
The laser itself (and housing & lensing, which are sometimes separate - gotta look into laser sources)
Driver for the laser (and possibly a dedicated power supply)
Heatsink for the laser (and probably fan)
... I think the rest is fixtures and just figuring out the physical layout. Operation would be handled within the start/stop scripts.
The more I roll this around in my head the more do-able it seems.
08-11-2016, 11:19 AM #2759
08-11-2016, 11:27 AM #2760
- May 2016
- Annapolis, MD
- 523
I've seen some implementations of this, but they were for the FFCP or Makerbot I think. One of them that looked interesting to me shot the laser between the extruders. The SS lasers are around $200-$250 for the 2.5 to 5.5 Watt range with their housing, electronics and wall wart PS (if the optical power numbers can be believed). They can cut balsa wood if it's thin enough. Meh... I think I'd want to use one outside, or have a really strong exhaust system set up. Not an option for me right now.
Completely new to 3d printing and...
06-13-2025, 01:52 PM in General 3D Printing Discussion
