Page 260 of 411 FirstFirst ... 160210250258259260261262270310360 ... LastLast
Results 2,591 to 2,600 of 4110
  1. #2591
    Super Moderator
    Apr 2014
    Location
    KS
    Add jfkansas on Thingiverse
    http://www.thingiverse.com/thing:390209
    This is a bolt on one that I've had out there for a while. It repositions the switch.
  2. #2592
    Engineer
    May 2016
    Location
    Annapolis, MD
    Quote Originally Posted by wirlybird View Post
    I had the nozzle to close. Just did a cleaning.
    I need to come up with a corner clip system for the glass.
    Check out this shim, I just found it. http://www.thingiverse.com/thing:1670502
    Is that one for 8mm or 10mm rods? It is a recent date...
  3. #2593
    Engineer
    May 2016
    Location
    Annapolis, MD
    Quote Originally Posted by jfkansas View Post
    When ya want to upgrade to 10mm rods? I have 3 kits ready. Let me know what color the plastic, I have many ABS colors. :-)
    OK, I'm ready when you are. The red material you had used in your prototype pix looked fine to me, was that ABS?
  4. #2594
    Super Moderator
    Jun 2016
    Location
    Oklahoma
    Quote Originally Posted by DaveB View Post
    10's he says and for using the zebra board. Wonder how that stuff works?
    It's printing now so I'll know shortly.
  5. #2595
    Super Moderator
    Apr 2014
    Location
    KS
    Yes, Verbatim red abs. It is good stuff.
  6. #2596
    Engineer
    May 2016
    Location
    Annapolis, MD
    Great. Sent you a PM.
  7. #2597
    Engineer
    May 2016
    Location
    Annapolis, MD
    Duhh. Sorry, the file name didn't show in it's entirety.
  8. #2598
    Super Moderator
    Jun 2016
    Location
    Oklahoma
    Ok, just printed this one http://www.thingiverse.com/thing:1670502
    fits great with the 10's it is made for a plate a bit thinner that .25" so be careful!!!
  9. #2599
    Engineer
    May 2016
    Location
    Annapolis, MD
    W, how is the Flexion install going?
  10. #2600
    Super Moderator
    Jun 2016
    Location
    Oklahoma
    Have not started yet. Wanted to get a few other little issues ironed out first. I think I found that a good first layer height for PLA is 70%. Leaving ABS at 90% for now, seems ok.
    The new shim is good. allows to crank down the adjusters more which I thin tightens it up a bit.
    Now trying to make new corner brackets to hold the glass in place. Once I finish these things I may start on the install. Looks like storms so this afternoon may be a good time to install and not print in case power goes out!
Tags for this Thread
