Results 11 to 20 of 40
Thread: PLA Suddenly Jamming Mid-Print
07-08-2016, 09:42 AM #11
- Jul 2016
- Pennsylvania, USA
- 255
Hi
If your fan is cooling off the hot end so it jams ... time for an upgrade.
Bob
07-08-2016, 10:38 AM #12
- Feb 2016
- 24
An upgrade... on what part? If you're suggesting the entire printer, then no. This printer is only several months old, I know that it functions fine with ABS, and it worked fine with PLA before I switched to ABS.
The theory about the fan over-cooling the nozzle is still just a theory, I haven't the time yet to thoroughly test it.
07-08-2016, 11:01 AM #13
- Jul 2016
- Pennsylvania, USA
- 255
07-08-2016, 04:46 PM #14
We have had issues in the past with a layer fan. The fan is designed to cool the layer just printed which helps with things like bridging. However, we found that the fan was cooling the nozzle to the extent that filament cool and hardened on the nozzle causing a clog half way through the print as you describe. I hope this helps.
07-16-2016, 08:20 PM #15
- Feb 2016
- 24
Okay, so I can't really give the full details, but through a lot of trial and error I feel that I am close to getting things working fully.
I have one last problem, and it is driving me insane, because I know what I want to do but I can't.
I want to disable the filament cooling fan when the printer prints the HIPS support material, and turn it on only for the PLA.
BUT, when I disable auto-cooling in the HIPS settings, the fan stays on anyways.
I found out that this is because Slic3r uses the M106 or M126 (depending on GCODE flavor) command to turn on the fan during the PLA, but it never triggers M107 or M127 to turn it off when the HIPS starts printing. I also see that most of the time the fan is enabled during the layer change rather than when the GCODE switches between the extruders.
Is there anyway to make the fan turn off for one filament and on for the other? I need to be able to do this.
07-16-2016, 08:25 PM #16
- Jul 2016
- Pennsylvania, USA
- 255
Hi
A hot end cooling fan should be on pretty much all the time. That is a different fan (in most setups) than a filament post print cooling fan. They make it impossible to turn the first one off. The second one is indeed controllable. You get a problem when the software is a bit confused about which function a specific fan is performing.
Bob
07-16-2016, 08:33 PM #17
- Feb 2016
- 24
07-16-2016, 08:37 PM #18
- Jul 2016
- Pennsylvania, USA
- 255
Hi
The fan setting may be confused in Slic3r or (more likely) it's confused in your Ramps (or equivalent) or your wiring.
Bob
07-16-2016, 08:58 PM #19
- Feb 2016
- 24
Okay, I don't think you're exactly understanding what I mean.
Here's an example part of the GCODE I'm currently producing in Slic3r: https://www.dropbox.com/s/jitinycgas...gcode.txt?dl=0
You can see where the GCODE turns on the cooling fan using M106 at the top.
I've noted each location where I want the code to turn the fan on or off, which is at each tool change. (I also edited out all the repetitive GCODE for brevity's sake)
What you don't see is that several more times in the GCODE file (about 60 times), the GCODE runs the M106 command. This normally happens when the print shifts to a new layer.
With how the GCODE is currently generating, I cannot make the fan only turn on for the PLA and not the HIPS. This needs to change, but I can't figure out how to make it work correctly.
07-17-2016, 09:26 AM #20
- Jul 2016
- Pennsylvania, USA
- 255
Hi
Ok, I promise I will no longer participate in this thread. Trying to work through a solution in an orderly fashion is obviously annoying you tremendously.
Bob
Completely new to 3d printing and...
06-13-2025, 01:52 PM in General 3D Printing Discussion
