Results 1,881 to 1,890 of 4110
06-15-2016, 09:54 AM #1881
- Nov 2015
- 43
06-15-2016, 10:12 AM #1882
Yes both use the same header. The second hex file adds USB.
06-15-2016, 01:32 PM #1883
- May 2016
- Annapolis, MD
- 523
I am looking for an effective way to check the dimensions on .STL files that I download from Thingiverse etc. The S3D SW provides an exterior max X, Y & Z dimensional display, but often that does not reveal the dimension info I am after. Any suggestions?
06-15-2016, 04:38 PM #1884
- Feb 2016
- 360
06-15-2016, 10:06 PM #1885
- May 2016
- Annapolis, MD
- 523
I've got Autocad Inventor. It imports the STL as a mesh of polygons, and displays it as that on the screen. Convincing it to offer up a specific dimension on that object is pretty chancy so far for me as the on screen interaction is one of selecting the appropriate polygons. It seems like there should be some way to turn that mesh into an object that I can manipulate, but I have not found it.
06-16-2016, 07:22 PM #1886
- May 2016
- Annapolis, MD
- 523
Anyone have experience using the Makergeeks "High Performance PLA" filament on a QIDI?
06-16-2016, 08:35 PM #1887
- Feb 2016
- 360
06-16-2016, 09:27 PM #1888
- May 2016
- Annapolis, MD
- 523
The Makergeeks website refers to the High Performance PLA as having both of those characteristics. They state that the dishwasher safe aspect is due to that material's high temperature performance (post anealing). What is it like? Does it behave more like PLA or ABS?
Just loaded some ABS on the QIDI for the first time. Did my first print and... Holy guacamole Batman, it prints like butter!!! My inital impression is Wow!
06-17-2016, 07:33 AM #1889
- May 2016
- 55
06-17-2016, 11:08 AM #1890
- May 2016
- Annapolis, MD
- 523
Using an IR spot thermometer, at a 60C setting the top of a 1/4" glass build plate on a Maghold platform is pretty close to 60C. But at a 110C setting, the top of the glass is only showing about 100C. Cranking up the setting to 118C got the glass surface to around 108C.
There also seems to be a good deal of thermal mass to the 1/4" glass plate relative to the capacity of the heater. It takes 3-4 minutes for the top surface of the glass to come up to temperature, even after the heater's thermocouple readback has stabilized at 60C. With the Maghold system, there are multiple layers of not-so-conductive material that the heat must traverse. There is a kapton layer on the exposed underside of the steel sheet, and another adhesive layer between the steel plate and the glass.
