Results 1,241 to 1,250 of 4110
04-26-2016, 05:34 PM #1241
- Aug 2014
- 627
For me I wouldn't as I run 110c-115c bed temps all of the time. Now if someone is only doing PLA/PET and prints these in ABS then rock on.
edit: Last few minutes and someone outbid me. Doesn't matter Emily told me what they would accept as a minimum so I just made an offer with that minimum and a note letting them know what Emily said to me.Last edited by DarkAlchemist; 04-26-2016 at 06:02 PM.
04-26-2016, 06:05 PM #1242
I've used the ABS clips on 110C bed temperature and it works. Eventually they probably will need to be replaced, but it is easy to print extras. I don't like them and have found a better solution, but I wouldn't flat out say that it isn't worth trying because it does work.
04-26-2016, 06:15 PM #1243
- Aug 2014
- 627
Of course they work unless someone had a bed up around 220c, heheheh.
What I meant to infer is that it is a bit of a hassle as I have seen a lot of people over a few forums asking why they worked and in a print or two would no longer grip the glass. Of course the answer is that it got soft when the bed was heated up and on a printer with a movable Y (like a Prusa I3 for instance) the clips will deform even more as the bed will jerk back and forth which deforms the soft/softer hole and the glass will move helping to deform them even more.
The above is why I went to four Gino pads over bulldog clips, or printed glass holders though if I had a way to find those holders in a material that would not soften at say 120c, or less, bed temps I would ditch the pads.
04-26-2016, 07:15 PM #1244
- Aug 2014
- 627
Well, by Tuesday I will be one of you and an owner of a Qidi Avatar IV. Emily accepted my offer and I just paid them.
I asked McMaster's about the weight of the 3/16in and 1/4in Boro glass and it was 1lb vs 1.2lb so which one should I get for this printer?
04-26-2016, 07:57 PM #1245
- Feb 2016
- 10
Thanks I had tried connecting to my Flashair card via \\IP_ADDRESS and it didn't work. I tried again just now and it did work! So it must have timed out before. Now I can map as network drive. That thread indicates it doesn't affect performance of printer access to SD card so should be good!
04-26-2016, 08:07 PM #1246
- Aug 2014
- 627
04-26-2016, 08:25 PM #1247
- Feb 2016
- 10
04-26-2016, 08:47 PM #1248
- Aug 2014
- 627
Yeah, this house is from 1959 and there is something in the hall bathroom that blocks signals. I tried everything including the router/modem the cable company gave me and ugh. Even on a computer that is about 10-15m away with a dual 6dBi antenna system it was so-so (yet another wall for it). My blu-ray player would not connect to it and it is in the same room as my printer. If my i3 was going forget anything from connecting.
So, I went to my own router with 3 antennas and it is almost max to the computer and my printer no longer affects anything but I never tried my blu-ray again (I used it to try and watch a movie from my main computer 10-15m away and it would freeze too much). So, on my phone the signal next to my i3 is around -70dBm and around -77dBm where the final computer is at (3 walls to it). Basically it is marginal unless the thing has a good external antenna or at least one better than a cell phone has.
edit: On this printer a 1/4in thick 1.2 pound Boro glass or a 3/16in thick 1 pound Boro glass as a "PC Glue" replacement?Last edited by DarkAlchemist; 04-26-2016 at 09:35 PM.
04-26-2016, 11:45 PM #1249
- Mar 2016
- 45
I did the cable chain install. Getting those black cable clips off were such a pain. They were using 5.5mm nuts, I only had 5mm and 6mm sockets. The base part, the screw was too short to screw on, I tried drilling a countersink but without a socket it was a nightmare to screw it on . So I ended up using double-sided tape to hold it in place lol. But surprising it is holding up well. I am not sure when printing in ABS with high heat, will cause it to come off. I did a 30 min ABS print and it is holding well though. The one thing I messed up was the cable for the LED light is supposed to be routed thru the base part, I only realized this after I stick it on lol. Oh well, maybe if It comes off I will re-route it.
Even though the install was such a pain, for me at least, I really like the outlook of how it turned out.
04-27-2016, 05:59 AM #1250
