Quote Originally Posted by g.gregory8 View Post
I have a Toshiba Flashair W-03 16GB card. Basically you can connect to this directly with WIFI or setup to connect to your local network. Then you access the local webpage it hosts and can view the files on it. You need to modify the user interface to allow uploading/deleting files, follow this guide. Then you simply navigate to the bookmarked webpage and click upload file and select your *.x3g file and it will copy to the SD card. Which you can then select and print as normal.
It would definitely be better if the SD card was accessable as a network drive/folder which would allow you to save directly there from slicer. But one more step of uploading file via webpage isn't too bad.
Looks like you can map a drive to the SD card. I think I need to order one.
http://3dprintboard.com/showthread.p...ped-in-Windows
Quote Originally Posted by DarkAlchemist View Post
Good to know and it is odd they didn't just make it like a network drive indeed. :/ Still, not a bad idea though I am not sure if that small thing could reach the other part of the house. My cellphone struggles but anything with an external antenna has no issues.
You phone/computer would not need to connect to the Flashair directly. The Flashair just needs a good connection to your WiFi router then your computer would connect to the SD card through the router.
