Results 1,141 to 1,150 of 4110
04-21-2016, 06:06 PM #1141
I use the Microswiss conversion on my Qidi and it works fine. I have made a couple deviations from Microswiss instructions.
1. I used a small amount of teflon tape on the threads of the tube that screws into the hotblock to prevent the leakage I was initially getting.
2. Microswiss instructions suggest a small amount of filing of the cool block hole that the extruder tube goes through. You don't want to do that.
3. I do use the heat sink compound on the extruder tube going through the cool block.
Your extruder mount conversions have been intriguing me for awhile now.
How would a downward cooling fan preferably a cage style fan attach to it?
04-21-2016, 06:13 PM #1142
04-21-2016, 06:14 PM #1143
- Aug 2014
- 627
Forget this printer then for me as M7x1 is an expensive nozzle whereas the MK8 M6 is a nice price AND a nice selection of sizes to choose from.
Oh, well.
04-21-2016, 06:42 PM #1144
From my experience (which isn't a whole lot) the MK10 nozzle is better than the MK8.
The Makerbot I was fighting with had the MK8 nozzle and it never worked very well.
04-21-2016, 06:57 PM #1145
04-21-2016, 07:14 PM #1146
- Aug 2014
- 627
04-21-2016, 07:26 PM #1147
Qidi sells them for $5.00 shipped but personally I prefer coated nozzles which are even more expensive.
http://www.ebay.com/itm/QIDI-TECHNOL...IAAOSwHnFVgifZ
04-21-2016, 07:33 PM #1148
- Aug 2014
- 627
You see there is a lack of diversity with these nozzles. I would love to have a 0.2,0.35,0.4,0.5,0.7,0.8,and a 1mm which I can easily get for a MK8 style. My main go to nozzles are 0.35,0.5,0.8 and 1mm depending and having a dual system I want it even more. For most of my printing a 0.4 is a step down for me.
04-21-2016, 08:04 PM #1149
DarkAlchemist, I don't think the Qidi is the right printer for you. In my opinion the Qidi is a great machine (not perfect) but you keep trying to find reasons that it is bad. I think you are trying to talk yourself out of it so I don't think you should get it. Just my 2 cents.
04-21-2016, 08:17 PM #1150
- Aug 2014
- 627
Yep, I agree with you it isn't the right printer for me after this information came to light. I prefer a printer where I can easily modify it and change nozzles etc... not one where you are locked in. So, I agree with you 100%
Besides Reprap who uses MK8 nozzles or are they all trying to lock you in with the MK10 stuff now?
edit: I went digging and found this - https://www.youtube.com/watch?v=UnI0aeTw9iA
The video is alright but this question, and their reply, is the sort of information I am after and it was only 7-8 hours ago too
aardvarker 8 hours ago
Thanks for the video. My printer came with the MK10, but I saw some people saying the MK8 is actually better (less stringing, and also cheaper replacement parts). Have you done any comparison between the two? Any insights on which one you prefer? I ended up getting an all metal hotend for the MK10, but still curious about the differences in quality / performance with the MK8.
ToyBuilder Labs 7 hours ago
+aardvarker The stock MK10 design uses a PTFE tube as the thermal barrier within the filament guide tube, resulting in a reduced melt rate of filament compared to the MK8 design with the stainless thermal barrier tube. You can see this during filament loading, where the same filament at the same temperature will flow a little bit better on the MK8 design. In terms of stringing, there should be little difference between the two once retraction and temperature are properly adjusted. The MK10 hotends do run a little hotter than MK8 hoteneds for their indicated temperatures - so the MK10 may be prone to stringing if you don't lower the temperature. In terms of parts costs, there are far more MK8-compatible replacement nozzles out there (due to its M6 thread which is a very popular thread size for a lot of printer builds. We sell our high lubricity wear-resistant MK8 and MK10 nozzles for the same price though.Last edited by DarkAlchemist; 04-21-2016 at 09:23 PM.
Completely new to 3d printing and...
06-13-2025, 01:52 PM in General 3D Printing Discussion
