Results 921 to 930 of 4110
04-13-2016, 02:58 PM #921
04-13-2016, 03:12 PM #922
- Aug 2014
- 627
Yeah, Mitsumi is who I went to for my 8mm rods on my I3 and I really like that company. I have to say they shipped the rods like it was Fort Knox and in the end I felt like I was opening one of those Russian dolls that opens up into a smaller one that opened up into a smaller one, etc.. VERY well packaged I must say.
KludgeGuru went to 12mm so is there anything that needs to be done to use 12? If this was a single extruder printer I would say 10mm would be fine but with two heavy motors on the rods I would have to say no because there is still a tad bit of deflection with a single motor on 10mm on an i3 and almost none (might as well say none) with 12mm hardened Mitsumi g6 rods on the same i3 when using just one motor.
Is that Carbon fiber platform the one I saw earlier that was taking the place of the metal base holder?Last edited by DarkAlchemist; 04-13-2016 at 03:17 PM.
04-13-2016, 03:24 PM #923
There really isn't any extra weight on the platform with 2 extruders. I went with 10mm rods for now on the Z. It could be easily modified to do 12mm though. I think 12 is overkill on a 150mm travel. The X axis could definitely benefit from at least 10mm rods. I have some stuff designed for it but haven't had prototype aluminum bits made yet.
Yep that is 5mm solid carbon fiber plate. There is no bending it. lol
04-13-2016, 03:32 PM #924
My 12mm rods are only on the Z-Axis, they are better than the 8mm stock rods but I'm not that happy about the bearings. The bearings have some play in them, not side to side play but I can twist the platform vertically up on the right and down on the left and vise versa (if that makes sense). I printed the adapters using PLA which seems to be fine since it doesn't get too hot in the chamber to deform them. I'm going to look for better bearings and eventually reprint in ABS.
I've also started thinking about upgrading the X-Axis rods to 12mm, but haven't made any progress yet.
04-13-2016, 03:36 PM #925
04-13-2016, 03:36 PM #926
If you reprint your top bracket and bottom bracket with the holes spaced .1mm (total or each side) wider than stock you might be able to preload some slack out of the bearings.
04-13-2016, 03:42 PM #927
http://a360.co/1Q7xlPV
It's really built as a complete system so just the plate might not work. Note also some build plate modifications will need to be done also. I have been wanting to move the Leveling screws out to the far corners for a long time so took the opportunity to do it on this. Adds to the cost, but I think it will be worth it.
I might try to cut costs a little by going to a 4mm or 4.5mm plate which both I think will be just as effective.
04-13-2016, 03:43 PM #928
- Aug 2014
- 627
X/Y really needs 12mm with those two direct drive extruders on them (which is what I was talking about) and I suspect 10mm would be enough for Z but not sure when you add the weight of boro glass on it (especially 1/4 or 5/16 in).
I really get this sense, a really sick feeling, Qidi isn't all that and a bag of chips because if they design this bigger printer I just feel it that they will use inferior rods in them to cut corners. 12mm is what it needs to be in anything larger. Can get away with 10mm if only 150mm long but at 300+ 12mm or stay home.
04-13-2016, 03:50 PM #929
Yep definitely, and the plastics they use for for holding the Z axis rods is considerably more flemsy than Flashforge.
I would space the rods out further on the Z also, it will stabilize the rotation since the build plate would have less torque on the rods.
04-13-2016, 04:08 PM #930
- Aug 2014
- 627
Agreed. Honestly, I saw this printer originally and after all I have found out this is at most a 400 dollar machine delivered. The only thing it has going for it is the all metal housing. People will think otherwise but for the money this machine costs I could make one hell of a 3d printer myself in the fashion of a RepRap or wander over to OpenBuilds and make one of those and save a few pennies. basically this is really an over priced machine for what it is. I am not saying it is a horrible printer I am just saying their "Engineers" need to go back to school.
