Originally Posted by
dspdrew
I spent an hour tearing this thing apart to fix the jammed up filament, and now it's jammed again. Every time I try to do a print, when it gets to about the 5th layer, the filament stops coming out of the nozzle. You can see it going in about 1/4 inch, then the clicking starts, then it goes backwards about 1/4 of an inch, and starts clicking. It keeps doing this over and over all the while nothing is coming out of the nozzle. Any idea what the deal is?
Edit: Okay, I can see that the way this thing is printing is what's causing these problems. I don't even understand why this thing is deciding to print this part the way it is. It gets to a point where it just sits there for about 2 or 3 seconds, then the bed drops down, and it continues. Each time it gets to that spot it does this again. Also as it's doing this, the filament is going in and out. I don't understand why it is generating gcode like this.
Another problem I'm having is for some reason every print I generate in Simplify3D won't heat the print bed up past 25C, even though I have it set to 50 on the temperature tab.
Completely new to 3d printing and...
06-13-2025, 01:52 PM in General 3D Printing Discussion
