Results 481 to 490 of 4110
03-09-2016, 12:48 PM #481
- Feb 2016
- 96
03-09-2016, 12:48 PM #482
- Feb 2016
- 96
Does anyone know how to control the LED light in the Qidi Tech? I assume there's only one light which is the white one on the top front inside of the case. For me it seems like it's always white but I see in the menu there are options to turn on and off the light and to set color. I've tried both of these settings and they don't seem to do anything.
03-09-2016, 05:34 PM #483
- Feb 2016
- 6
Does anyone know what type of nozzle these machines have? going to experiment with some of the abrasive proto pasta filaments but want to have a spare on hand.
03-09-2016, 05:58 PM #484
03-09-2016, 06:25 PM #485
- Feb 2016
- 6
03-09-2016, 07:58 PM #486
- Mar 2016
hey guys. just got my qidi!
I downloaded the simplify3d software but am having trouble locating the printer!
Also what model should I choose? I chose FF pro and nada.
Help me!
03-09-2016, 09:13 PM #487
- Mar 2016
03-09-2016, 09:50 PM #488
Yes MK10 nozzles should be the same height. You adjust your hot block/nozzles with the tube connected to them in the cold block.If your going to print with abrasive filaments you may want to look into theses.http://www.micro-swiss.com/#!product...e-cece31e3ba6f
03-09-2016, 11:33 PM #489
Yup, printed with ABS and PLA. From the Simplify 3d defaults you will want to lower the extruder temperature for PLA to 200-205C. The bed temp should be around 50-60C.
If you have any print quality issues check out their troubleshooting page:
https://www.simplify3d.com/support/p...oubleshooting/
03-09-2016, 11:39 PM #490
- Mar 2016
guys I am having a hard time or rather no luck whatsoever getting simplify 3d connect to the printer!
I get fail to connect message over and over!
