Thread: SSR or Mosfet
01-05-2016, 11:50 AM #1
SSR or Mosfet
I have a Geeetech Prusa i3 x and was wondering if and how anyone else has ran their heatbed off of an external 12 or 24v power supply. From what I been reading, I think whatever you use you have to use a diode for backfeed but I was wondering which one would be more reliable and work the best. Thanks guys
01-05-2016, 02:14 PM #2
- Jul 2014
- 305
01-05-2016, 07:15 PM #3
Typically, the mechanical relays with an electromagnet need a reverse biased diode across the relays coil. That is because when the current is switched off to the relay's coil, you get a big inductive kick that can fry the circuitry driving the coil. That is the only time a diode is required as far as I know. And a you wouldn't need that with a solid state relay because there is no coil. Maybe the Solid State Relays need a diode for another reason?
01-06-2016, 03:18 AM #4
- Burnley, UK
- 1,662
