Results 21 to 30 of 40
Thread: simplify3d
10-21-2015, 06:50 PM #21
- Sep 2015
- South Australia
- 89
10-30-2015, 07:35 AM #22
- Oct 2015
Has anyone worked with ReplicatorG? Can i have a comparison with S3D?
10-30-2015, 11:30 AM #23
RepG is outdated free software that hasn't been actively developed for almost 4 years. S3d is actively developed/supported commercial software. Really hard to compare.
10-30-2015, 12:57 PM #24
rep g takes about 4 hours to slice the lefabb articulated elephant (can't give you an exact time after 3 hours I gave up and never used rep g again).
Simplify3d takes about 30 seconds.
10-30-2015, 01:01 PM #25
- Feb 2015
- 371
Can s3d do mesh mixes like Slic3r does? I want to explore some of the options printing with different fill densities on a single part can offer. I know you can use different settings on separate parts on the prints, but what about separate sections of the same part?
10-30-2015, 01:32 PM #26
yes - I think, not sure what you mean.
You can have any number of processes on a single print, seperated by vertical height.
You could simply have the print in different bits - apply a seperate process to each part and then move them together om the printbed.
Essentially ending up with one single object with a variety of different settings.
It won't cut a print into different bits though - that would be useful.
10-30-2015, 01:35 PM #27
- Feb 2015
- 371
This is what I mean...
http://slic3r.org/blog/modifier-meshes
10-30-2015, 02:29 PM #28
in that case - yes.
All he's done is create two models. Applied different settings to each and then stuck them together.
10-30-2015, 03:25 PM #29
- Feb 2015
- 371
Kinda. The second model just provides an area that modifies the initial part. It doesn't simply create two parts. When you load the second part as a modifier it won't slice that part. It only tells the slicer anything in this area gets different setting applied.
10-30-2015, 04:24 PM #30
- Aug 2015
- 256
No you don't need to create your own supports, but if you're having problems with supports not adhering to the build plate, a thin model placed under the support will help.
If you have problems with parts curling off the supports, then you may need to adjust your model--adding a few fused support that anchor it to the build plate.
