Results 31 to 40 of 40
Thread: simplify3d
10-31-2015, 06:32 AM #31
11-06-2015, 07:54 AM #32
- Oct 2015
- 4
Where can i find the manual of Simplify? I mean there are a lot of parameters to adjust, where can i find out what, each one of them, does?
11-06-2015, 10:17 AM #33
1/ If you let your cursor hover over a parameter it gives basic explanations.
2/ They have a Support Page with more detailed scenarios/tutorials
3/ On their support page they have a troubleshooting guide that explains what parameter to work on based on what your print looks like.
4/ They have nice support by email. They answer fairly quickly and are quite OK.
11-06-2015, 02:57 PM #34
- Aug 2015
- 256
11-08-2015, 02:48 AM #35
- Oct 2015
- 4
Great answer dude, thanks a lot! I usually go for the official manual first and if that isn't good enough to cover what i need then i google it.
11-08-2015, 06:11 AM #36
try this: https://www.simplify3d.com/support/
I'm not sure there is an actual manual.
I haven't seen one - but then if you go through the stuff on the support page - you shouldn't need one. And every setting has it's own info bubble.
And google is a pretty lousy search engine, yahoo is better. dogpile gives you a selection from more than one.
01-09-2016, 09:04 PM #37
- Jan 2016
- 10
Hi, I wonder if simplify3d is compatible with the Flashforge Dreamer?
01-09-2016, 09:24 PM #38
Yes it is, but have to export gcode from Simplify3D and bring into FlashPrint.
01-17-2016, 05:03 PM #39
- Oct 2014
- 93
01-17-2016, 05:26 PM #40
- Oct 2014
- 93
so i put up the cash this last week, got laid off form my job of 21 months due to ill health (yep right before my 2yr, more rights thing kicked in) either way i got a nice payout (cant specify, confidentially clause), but anyway im finding this software well worth the money, no problems with sticking to the bed (i have a flexi build plate), dense supports are great easy to remove. i still get some sagging on the dense layer, im printing at 205 for pla, think i mite back it off to 200 see if that helps.
one called "wave tealight holder" (cant seem to find a link for it now) prints fine, but as the upper surfaces are not seen as solid, they print very thin, similar to the 2 perimeters of the rest of the print, also the inner layers are not meeting the perimeter layers, as in in getting some gaps, my bed is adjusted correctly.
any help
Today, 04:18 AM in Tips, Tricks and Tech Help
