12-01-2013, 11:33 AM #1
Taulman 645 High-Strength 3D Printer Filament
Taulman 645
High Strength, Durable, and Non-Toxic
Taulman 645 String Supporting 10lbs!
The Taulman 645 3D Printer Filament is made by the same company that produces Taulman 618. 645 is a very high strength and durable Nylon-based Filament. Like Taulman 618 it excels at artistic projects as well. Taulman 645 is strongest when the layer height of the filament matches the diameter measurement of your Extruder Tip/Print Nozzle; a 1 to 1 (1:1) ratio. 645 is transparent by nature but can be colored using dyes. Not only is 645 structurally strong, a large part of its durability is due to 645 having a very high resistance to degradation/break down from being exposed to chemicals, making it especially suitable for industrial environments. According to the creator, on taulman3d.com; “Greater resistance to chlorine, chlorides and bromides in addition to Alcohols, Resins+MEK, Oils, Acetone, Most all Alkaline, most 2 part Casting Compounds“.
02-17-2014, 11:55 PM #2
- 24
In addition, Taulman 645 is a high quality, very easy-to-print industrial grade nylon filament which natural color is clear. The 645 is an extremely strong material compared to for instance ABS filament and it will deliver beautiful printed finish.
02-24-2014, 01:17 PM #3
Login Error
