Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Low Filament Sensor
    Hey guys my name is Justin, and I am an inventor and 3d printing enthusiast. I just finished testing my low filament detector for 3d printers. When your filament runs low it will sound the alarm giving you time to pause or reload your filament. This item is very simple but also very reliable, when your half way through a five hours print and your printer runs out of filament, this will save the day. It will also save you money by letting you use that last little bit of filament left on each roll.
    Each unit comes with 5 tops so you can pick the color that matches your printer.
    It will work with 1.75 or 3mm filament, by changing a part that is included.
    I have it listed on my website eBay and amazon if you want to get it on my website use promo code reedswitch for 10% off.
    My website
    http://www.endlessparts.com/collecti...ant=8789525379
    eBay
    http://www.ebay.com/itm/low-filament...-/252117789218
    Amazon
    http://www.amazon.com/Filament-Senso...ilament+sensor
    Check out the videos.
    https://youtu.be/L4p95UDboJU
    https://youtu.be/5jFUWdbMdmoIMG_1555.jpg
  2. #2
    Very Interesting !
    I'm curious what type battery it uses
    and is it easy to replace ?
  3. #3
    i uses an off the shelf coin cell battery that cost less then a dollar.
    you can replace it as needed but it will last years.
  4. #4
    Jul 2014
    so it beeps when the last bit of filament goes through ?
    Shame you can't monitor the actual filament on the roll.
  5. #5
    Quote Originally Posted by curious aardvark View Post
    Yes, It Should be called the 'NO filament sensor' instead of the 'Low filament sensor' !
  6. #6
    Technician
    Sep 2015
    Location
    San Pedro, CA
    I actually had a similar thought. Except, attach the switch end to a potentiometer to measure diameter variance in a section of filament as it is pulled through.
  7. #7
    Quote Originally Posted by LAFilament.com View Post
    ! ! ! You Really Worry That Much about 'Diameter Variance' when you print???
    What are you going to Do if it's a little out of tolerance?
    Trash the Whole Spool ?
    Or are you talking about when Making filament ?
    I can see that would be Very Important when Making filament !
  8. #8
    Technician
    Sep 2015
    Location
    San Pedro, CA
    Quote Originally Posted by EagleSeven View Post
    Not specifically for when I print. Just a "shower thought" so to speak.
  9. #9
    Ah, one of Those !
    I understand completely ! LOL
  10. #10
    The main problem we would have with 'Low filament sensor' is there is Only about 1" if filament that is exposed
    outside the guide tube, going to extruders, at spool.
    and there's no where to hang or attach the sensor at that 1" location .
    Would require a special bracket mounted on back of printer
    and it would make loading of filament even more difficult than it is already .
Tags for this Thread
