Results 1 to 10 of 10
06-15-2015, 11:53 AM #1
- Jun 2015
HICTOP Prusa I3 3D - 270*200*170cm
Just got one and assembled it. Found this forum and didn't find thread for this printer so decided to make one.
Anyone else out there have it?
Hardware seems to be good, still working on adjusting it.
One issue was the y-axis limit switch did not contact anything. Built a tab out of scrap stuff that I double-sided taped to the frame so the limit switch has something to contact. Seems to work very well.
Any other problems out there?
06-15-2015, 06:37 PM #2
Interesting. Do you have a link to any information regarding this machine? I like exploring everything that's out there.
Welcome to the forum by the way!
06-15-2015, 10:10 PM #3
- Jun 2015
Here is the link from Amazon:
http://www.amazon.com/gp/product/B00...ilpage_o02_s00
06-16-2015, 05:42 AM #4
it's an iprusa kit - I think you'll find plenty of threads and a whole section on reprap and iprusa :-)
http://3dprintboard.com/forumdisplay...-Printer-Forum
10-02-2015, 11:52 AM #5
- Sep 2015
10-02-2015, 12:00 PM #6
- Sep 2015
zrodsupport5.stl
I have been "PLAYING" with my HicTop metal Alum printer for about 6 weeks now. I have noted a major problem in the Z axis rod capture on the Z axis motor plates. They wobble badly, I reported the problem to HicTop and designed a solution. I added a thin plate to the outside of the Z axis motor plates, this stabilizes the lower Z rods. I kept the plate thin as to still used the original screws.
Happy Printing.
Bob
10-18-2015, 10:47 PM #7
- Oct 2015
I am new to 3d printing and just constructed the HicTop aluminum body. I'm having issues with the z-axis. Would the Z rod support help with the rattle I have in the Z axis or is the axis not level.
10-18-2015, 11:51 PM #8
- Sep 2015
I am by far not a expert, only had mine for a little over 2 months. My "Rattle", wobble or vibration of the "Z" axis, was a combination of not parallel Z rods (fixed), the design of the screw capture of the "Z" axis screw drive(in the coupler to the "Z" stepper motor) and the "Z" axis rods not completely captured in the "Z" stepper motor metal support(bottom of the "Z" rods) . After verifying the parallel of the "Z" axis rods, I tried to add a thin spacer to the tops of the "Z" rods, sorta worked, but not completely. So I designed the zrodsupport.stl included in my previous email.
The only other thought I have of your vibration is the linear bearings, I have had a bad one on the "Y" axis. Normally pops and sometime grabs, not a smooth slide.
Look at the bottom of the "Z" axis rods, are they wobbling? You can try using my fix, at your own risk. I can see how it would hurt anything, if installed correctly.
Bob
10-19-2015, 12:33 AM #9
i think you should show yr result , and then let me look this machine ,i just kown a little bit about your opinon and discribe, i'm not clear.
But it's interesting,u can keep going and finish them.
03-03-2016, 09:58 AM #10
- Feb 2016
- Durham, NC
- 20
Hey. I have a HicTop black plastic.
Does your fix go over the motor axle with a bearing?
Or what?
