Results 221 to 230 of 232
06-11-2015, 02:23 AM #221
- Nov 2014
- Brevard, NC
- 182
I saw someone was looking for a way to clear their prints off the build plate remotely. There was a new design on thingiverse that seems to handle that problem. Take a look at this novel design if you have not seen it. http://www.thingiverse.com/thing:872617
It probably would not work well for buildtak or similar surfaces. I have to pry parts off with a knife from the buildtak surface sometimes.
06-11-2015, 03:49 PM #222
- Feb 2015
- 371
Trying to get Octoprint to work and when I try and print something I get a waiting for user message on the LCD display. Nothing prints.
06-12-2015, 06:19 PM #223
06-15-2015, 05:14 AM #224
I have seen this with Octoprint and auto bed leveling enabled. The host side will timeout during bed probing. The pathology I saw was during the bed probing, octopi will timeout and the printer will display a message "M105" and stall until the user presses the the dial on the printer LCD as clough42 describes.
Once I changed all of the timeout settings (except auto detect) to 30 seconds this stopped happening.
06-15-2015, 08:15 AM #225
06-26-2015, 11:37 PM #226
- Jun 2015
- 10
Has anyone implemented these neat add ons sucessfully?
Automatically upload timelapses to Youtube
Send an email after a print finishes with a snapshot
( https://github.com/foosel/OctoPrint/...ful-Eventhooks)
I have been trying to get these working to finish off my install but whenever I modify the config.yam1 file the server becomes inaccesible and I get a 503 error on my webbrower if I access it locally or over the internet. I feel like I dont get the syntax correct for adding these changes but if anyone else has managed todo this and could shed some light it would be much appreciated.
06-27-2015, 12:59 AM #227
- Nov 2014
- Brevard, NC
- 182
With a google search, I found these 3 web pages that may help you with yaml syntax.
http://docs.ansible.com/YAMLSyntax.html
http://ess.khhq.net/wiki/YAML_Tutorial
http://docs.octoprint.org/en/devel/c...nfig_yaml.html
06-27-2015, 03:40 PM #228
- Jun 2015
- 10
That was very very helpful turns out I was spacing things incorrectly. Thanks alot.
Unfortunately I've hit a new roadblock. Previously I didnt have an issue connecting to the printer and I hve tested moving the printer axes before. Now after uploading my first file it throws an error when i try to connect to the printer saying Machine Status: Error:volume.init failed. Any ideas what might be causing this?
06-27-2015, 03:59 PM #229
- Jun 2015
- 10
Hmm I take that back turns out just because the server error is gone doesnt mean I entered the information in correctly...I commented out the section I added and tried again and was able to connect. Damn it.
06-27-2015, 09:40 PM #230
- Nov 2014
- Brevard, NC
- 182
At least it is working for you now. Hope you figure it out. I have not tried the task you are attempting. Maybe someone else here will have a suggestion for you.
Login Error
