05-18-2015, 08:48 AM #1
A unique device for painting 3D prints comes to Kickstarter
Keith Redmond says he's just completed his design for the 3D Model Painter, a device designed to paint models using a rotating stage, 3D software and sensing technology to selected the areas which require painting via a spray system. The final prototype is currently being built in China and will ultimately be produced in Ireland if the Kickstarter goal is met. It must be said that while the project is woefully thin on details - there are no examples of the device at work - Redmond says it's capable of taking a 3D printed model and applying the necessary colors via an included software program by moving the target model on a rotating table as paint is applied. You can read the whole story here: http://3dprint.com/66183/painter-3d-...r-kickstarter/
05-19-2015, 04:35 AM #2
- May 2015
I think it is a big heap of poppycock
Nothing in that campaign convinces me to make an investment of that magnitude.
It's one of the most expensive KS-items I've seen to date and one of the least convincing campaigns.
If it is all true it would be awesome, but not even even a single picture of an object supposedly painted with a beta version of the product?
Pass.
05-19-2015, 05:22 AM #3
at the end of the day, there are at least 2 systems that will convert most 3d printers to print full colour models in the works. Which should be available before this and at a much lower price.
It's an interesting idea and if it also doubled as a 3d scanner then it might just be worth the money.
ie: it scanned the model, you printed it and then using the scan data it painted the printed mono colour model. That might conceivably be worth the money.
New member with print issue
