Results 101 to 110 of 156
Thread: Rumba and Auto-Bed level
03-12-2015, 06:07 PM #101
- Feb 2015
- 211
03-12-2015, 07:27 PM #102
- Feb 2015
- 371
It is frustrating. At times they are off by .5mm other times they are too small. I went through, cleaned, and tightened everything. Hopefully that will help even though I didn't find anything loose.
Parts is still do not have a finished appearance. I'm going to try some different filament. Maybe that may help.
03-12-2015, 08:31 PM #103
- Feb 2015
- 211
Unless you need the heat resistance I would recommend switching to PLA, it prints much better than ABS in my experience. The only ABS I have tried though was two rolls that I bought with the printer kit so different ABS may print better than what I got with the printer.
03-12-2015, 08:57 PM #104
- Feb 2015
- 371
Do I need to add part cooling fan for pla?
03-12-2015, 09:06 PM #105
- Feb 2015
- 211
03-12-2015, 09:35 PM #106
03-31-2015, 10:10 PM #107
- Dec 2014
- 43
So I finally was able to get around to set up my ABL. Everything is hooked up with servo and working fine to find the position for the servo arm. So when I go to home the x or y axis it moves away from the enstop. But in proterface all the axis move in the right direction. I am using tsteever's frimware he uploaded.
04-01-2015, 07:49 AM #108
- Feb 2015
- 371
Hmm, wish I could help more. What happens when you home using the lcd? How about safe homing? Do you have that enabled?
04-01-2015, 10:21 AM #109
- Dec 2014
- 43
So its only the x axis that moves the wrong way. If I tap the endstop with my finger it will stop while moving. Everything else works fine y axis moves the right way and the probe arm for the z ABL drops and homes perfect.
04-01-2015, 11:29 AM #110
- Feb 2015
- 211
