Results 91 to 100 of 113
Thread: PEI Sheet for Bed Adhesion
03-09-2015, 09:26 AM #91
03-09-2015, 10:40 AM #92
- Nov 2014
- 522
It is a cheap set of lights i got from costco for 20$ i have my octoprint setup to do timelapse, overhead lighting leaves a lot of shadows so i got the lights and put a paper towel over them to soften the light so it wouldnt wash out the picture.
i have it setup to broadcast over the internet so i can monitor it from anywhere
and yes i print inside an enclosure
03-09-2015, 01:20 PM #93
- Jul 2014
- Eastern Colorado
- 536
What is that part on the right of the bed, with the six circular brims?
03-09-2015, 03:22 PM #94
- Nov 2014
- 522
that would be the dual E3D cooling shroud :-)
03-21-2015, 09:17 AM #95
- Jan 2015
- 445
I just finished my 12" i3v last night, and ran first two test prints (good early results). Now ill attach my pei and let it roll.
So you are aware guys, the PEI (the one from amazon at least, not sure about MC) has 2 sides to it with different properties.
1 side is glossy, 1 is matte.
glossy works great for PEI without needing to sand, and the matte side is great for abs, but needs some fine grit sanding every 5 parts or so.
I have been using PEI for about 4 months with STUNNING results. So i plan on putting a glossy side glass piece on, and a matte.
REMEMBER - DO NOT use PEI with ninjaflex, it will literally not come off. It took me 45 minutes to peel off a 3 inch part..
BTW< i use pei with the 3m adhesive sheet. for the prusa, ill attach them to glass sheets.
thanks
03-22-2015, 10:34 AM #96
- Dec 2014
- Canada
- 498
i havent noticed a matte side. its all glossy. i havent sanded
printed dozens of times. i barely even clean it
03-22-2015, 10:35 AM #97
- Dec 2014
- Canada
- 498
03-22-2015, 11:54 AM #98
- Jan 2015
- 445
03-24-2015, 05:52 PM #99
- Dec 2014
- Canada
- 498
ive recently had issues with adhesion
i ended up taping the PEi to my glass using Tessa Double sided tape
i have the PEI sheet a light sanding with a 300 grid sandpaper
im getting alot of lift at corners. not sure why
printing at 120 bed temp
03-24-2015, 05:59 PM #100
I still get some lift, I think I need to build an enclosure. However when I use a brim I don't have lifting problems, just would prefer not to print with a brim. I sand mine with like 1,000 grit, and then wipe it down with rubbing alcohol. I print at 105 to 110 bed temp, been tempted to try higher but haven't yet.
