Results 271 to 280 of 476
Thread: Itty Bitty Double Extruder
01-26-2015, 01:02 PM #271
Issue a G28 then G29 manually and see if it completes the routine.
01-26-2015, 01:17 PM #272
- Jan 2015
- 17
It does complete both routines. On G28, it moves to X, Y, then near center of bed and Z. On G29 it maps the glass in a 3x3 grid and retracts the probe, leaving the extruder in the last position of the test.
For my Start G-code, shouldn't these commands occur after the bed and hot ends are heated to allow for proper thermal expansion? I see that Clough's code appears to accommodate for this, but I'm not able to get a print started with it yet.
Edit: I just successfully started a print. It's still a bit too high off the bed, but at least it's trying to print ON the bed now. I *think* disabling the eeprom commands helped. Will keep tweaking.Last edited by paulpangrazzi; 01-26-2015 at 01:30 PM.
01-26-2015, 01:20 PM #273
Yes your start G code should heat first. Ill post my start code later when I get home.
01-26-2015, 06:41 PM #274
- Dec 2014
- Canada
- 498
First test print
http://youtu.be/Fh9bkObiFOU
01-26-2015, 06:46 PM #275
- Dec 2014
- Canada
- 498
01-26-2015, 07:09 PM #276Bambu P1S/AMS
01-26-2015, 07:09 PM #277Bambu P1S/AMS
01-26-2015, 08:22 PM #278
- Dec 2014
- 49
No matter what I do, I can't get the hotends level...my right side Z-nut spins itself out of the nut trap by the time the right side hotend touches the paper (see gap on right side in photo). I'm at a loss...
01-26-2015, 08:45 PM #279
01-26-2015, 09:03 PM #280
- Dec 2014
- 49
