Page 8 of 15 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 148
  1. #71
    Engineer
    Jul 2014
    Location
    Eastern Colorado
    Ok, I did some testing, and I found out why the code keeps getting repeated. I'll explain it in the other thread so I don't hijack this one.
  2. #72
    Engineer-in-Training gmay3's Avatar
    Mar 2014
    Location
    USA
    Add gmay3 on Thingiverse
    Ok so here's a little update on progress of the rear mounted, angled filament spool holder design.
    I finished creating models that fit correctly as replacements of the left and right LCD bracket parts. I am planning to create a 3 part holder similar to my LED snap on tray that will extend from these new left and right LCD brackets. When this first prototype is complete, I'll be able to see what reinforcement might be needed after this first prototype.
  3. #73
    Technologist
    Aug 2014
    Location
    Oklahoma
    Add usarmyaircav on Google+ Add usarmyaircav on Thingiverse
    Quote Originally Posted by gmay3 View Post
    Looking forward to seeing this!
  4. #74
    Technologist
    Aug 2014
    Location
    Oklahoma
    Hey gmay3, just wondering if you had seen this google plus post. https://plus.google.com/u/0/11396936...brctP2H?cfem=1
  5. #75
    Mar 2014
    Location
    USA
    Quote Originally Posted by usarmyaircav View Post
    Hey usarmyaircav! No I actually hadn't seen this before. This seems like a great design to keep filament environmentally stable and it's a good example of horizontal filament mounting. I like the use of filament guide tubes too, pretty cool.
    I haven't seen the need to use desiccants to dry out my filament in a container in my environment in Philadelphia. My primary goal is to extract fumes from the printer and make the printer/powersupply/filament/octopi be in one standalone enclosure to I can move it around easily.
  6. #76
    Super Moderator RobH2's Avatar
    Nov 2013
    Location
    Baltimore, MD
    Add RobH2 on Thingiverse
    I like that sealed filament design in theory. If you never swap out types of filament its particularly attractive. I keep my filaments in white 5gal. restaurant buckets with sealed screw lids that have 2" of desiccant beads in the bottom. I'm in Baltimore and have experienced some moisture issues. But not since I started storing the filament this way.
    Bambu P1S/AMS
  7. #77
    Mar 2014
    Location
    USA
    I saw this bit of genius today:
    http://www.instructables.com/id/Buil...inky-projects/
    I'm thinking of maybe incorporating a cook top range hood it into the design. I've seen models that incorporate a light bulb outlet, extractor fan, two speed exhaust fan speed control, and connection to outdoor ducting all for around 40 dollars. Not to mention material to make a top face of the enclosure!
    I'm guessing that on the max output of these things it would be too loud and windy to print but the lower setting might work.
    I'd be interested in hearing what you guys think!
  8. #78
    Technologist
    Aug 2014
    Location
    Oklahoma
    Makes pretty good sense. I was wondering about a flexible exhaust hose for out a window, with some type of baffling so the cold air doesn't come back in. Too complicated?
  9. #79
    Engineer
    Jul 2014
    Location
    Eastern Colorado
    I'm still working on my "curtains" concept enclosure for the printer. I've got the mounting pieces designed, I just need to print them out and assembled. As for my filament, I got a medium sized clear plastic bin, wide enough to hold 5 MakerFarm spools on a horizontal rod (1" dowel) with the plastic colour-change bead desiccant on the bottom.
  10. #80
    Mar 2014
    Location
    USA
    Yes absolutely my plan. Right now I have access to the clothes dryer exhaust (4 inch flexible metal ducting) to get it out of the house. Later on I would be interested in using a more discreet plastic flexible tubing like a 3 inch or so to vent out a window. Reducing the ducting size also will reduce the airflow in the enclosure which might be a plus if the default fan speeds are to fast.
    The hoods I'm looking at come in 30 inch wide and 24 inch wide models. I'm guessing the 24 inch is the way to go. The exhaust ports on them mate to either a 3-3/4 inch by 10 inch rectangular duct or a 7 inch circular duct. Both are adaptable to 4 inch circular ducting used from the dryer exhaust.
    Something to exhaust could be easily made with baffling that could go into a window. Or there are things like these available.
    http://www.amazon.com/Plastic-Whynte...ust+window+kit
Tags for this Thread
