11-22-2014, 05:40 AM #2
- Nov 2014
big experience
thank you very much for the wonderful and interesting article.
I'll tell you why I made this model.
The key chain marvin oltree to be a sympathetic figure and reference at the community of makers is also an excellent test for the printers:
bridges, half bridges, overhang, etc ....
I noticed that large format printers show much more difficulties than little ones, such as for exemple half bridges that in this case they are 6-7 cm long; or the support material that has been generated only for overhangs of 15-20 °.
The infilling inside and the perimeter is calibrated to have excellent mechanical strength, low weight, and the best possible finishing.
The simulation in these operations is essential, if you fail gcode, you lose a lot of material and time.
anyway
Marvin has been realized without initial test print, only a test without filament for two days to calibrate the machine and the printing speed
My only goal was to test the capability of my 3d printer:
- printing time
- print finishing for the whole printing period,
- a good surface finishing on the big overhangs,
- behavior on internal bridges of 6-7 cm
180h is a great time to evaluate the reliability of the printer, but it is absolutely not acceptable for the industry.
therefore
the next target will be to reduce by four times the building time allowding PivotMaker to became a benchmark for large format printers.
I am very happy for this result and I am looking forward to creating more
Thank you again Eddie
Cheers
ps. very soon i will upload the time lapse of the entire printingLast edited by i3D; 11-22-2014 at 06:12 AM. Reason: errata corrige
