10-28-2014, 11:47 AM #1
- Apr 2014
Echoing / shadowing / blurring features
Does anyone have a problem with text or other small surface features being echoed which makes them appear blurry from a distance?
Attached below is a recent part that shows an example of what I'm talking about. The "S" is repeated several times in front of the actual feature. I have a part that that has diamond plate diamonds that are also echoed before and after the feature which really takes away from the look. Does anyone have any suggestions?
10-28-2014, 12:51 PM #2
Schultz,
Did you design that part fresh, or was it converted from a 2D logo that perhaps had some shading effects?
10-28-2014, 03:14 PM #3
That's kind of a cool effect if it was the intended effect. Once you figure out what causes that, keep that in your toolbox.
10-28-2014, 08:16 PM #4
Yes, and we are currently looking at it in the Flashforge Forum, Dargonfly has almost solved it on his machine, it has to do with the acceleration settings from what I've read so far.
http://3dprintboard.com/showthread.p...n-Flashforge-)Hex3D - 3D Printing and Design http://www.hex3d.com
10-28-2014, 09:55 PM #5
- Apr 2014
This was designed by one of the other engineers that I work with in ProE and was saved as a STL and then brought into Simplify 3d for printing. It's printed on a 3DP printer.
