Results 1 to 10 of 21
09-12-2014, 08:24 PM #12
Viewed the video. It provides a good explanation of the process, however, I have these questions:
1. Where do you define the measurement system. I see that at the end of the process, you can scale in millimetres, but what is the measurement system used in the earlier stages such as when setting depths within the boundaries of the object? (Adding Decoration section)
2. Are our American friends required to use the metric system when the stl file is generated, or can the file be generated in the Imperial system?
3. How would you use this software to create an object such as a rubber duckie like this?
4. Would you add narration to Tutorial 7, please?
OME
New member with print issue
