Results 1 to 10 of 64
07-23-2014, 12:20 AM #7
- Jul 2014
- 305
Sorry for the double post.
After playing with Slic3r and Repg I found I can successfully use them together. The only issue is when I input the build dimensions of my printer 150mm X 145mm and set the center point at 75 X 72.5 two things happen:
When the extruders move to the front left to warm up it is hitting the side of machine creating a crunching noise. Then when it goes to print it prints off the build table on the back right side. So I then selected the center to be 0 X 0 and it then posts closer to the center but still makes the extruder hit the left side of the machine.
I will play with the dimensions more to see if I can get it to work better.
Also before it starts printing it releases a large amount of material and then begins to print the skirt. Anyway to modify the gcode with this?
