Thread: general question on files.
03-16-2023, 11:50 PM #1
- Mar 2023
Would like to know if I can save multiple files to print on the sd card. If so do I just select the one I want to print from the menu screen. Newbe here and just started the sample file that came with the printer.
03-17-2023, 01:26 AM #2
- May 2020
- 632
Shouldn't be a problem apart from having to scroll through them to find the one you want if each file is just a line of text.
I save mine on a PC and transfer to an SD card as needed then delete them afterwards.
03-17-2023, 10:30 AM #3
- Mar 2023
thank you for the help. I will try and add a few to start out with.
New member with print issue
