    general question on files.
    Would like to know if I can save multiple files to print on the sd card. If so do I just select the one I want to print from the menu screen. Newbe here and just started the sample file that came with the printer.
    Super Moderator
    May 2020
    Shouldn't be a problem apart from having to scroll through them to find the one you want if each file is just a line of text.
    I save mine on a PC and transfer to an SD card as needed then delete them afterwards.
    thank you for the help. I will try and add a few to start out with.
