05-18-2022, 03:09 AM #6
- 885
If you have other filament with which to try, that would be another point of information. 60 mm per second is a pretty good speed, but what happens if you drop it to 40 mm per second? It appears in the photo that you are using a raft, is that correct? Do you print without a raft?
