  1. #1
    specs on 3d printer check
    Hello to all,
    What specs should i check on a 3d printer,to get the best result in printing figures?
    To have the best result in layers vissibility.
    Thanks
  2. #2
    Jul 2014
    all of them :-)
    First you need to give us a budget.
    then some information about what you want to print.
    Then whether or not you'r prepared to go thorugh the resin post processing procedure.
    For model figures, resn printers are generally better.
    But they can be messy and you will have isopropyl alcohol around so need to make sure the containers are fume tight. And a uv light source for curing is also a good idea.
    Although if you live somewhere really sunny - you can get away with using the sun instead :-)
    The more information you give us - the more relevant an answer we can give you
  3. #3
    thanks !!!
  4. #4
    Quote Originally Posted by curious aardvark View Post
    all of them :-)
    Thanks for your kind reply.
    Not interesting in resin,i see its messy pressigure.
    I want to print mostly figures and get best details possible with pla.
    My budget is 1000-1500 euros
    And also get and bigger size possible.
    I have seen hundrents of products,but nowhere i have find a discution to covers my needs.
