02-13-2020, 02:34 PM #1
- Feb 2020
The noise issue of stepper motors used in 3D printer
I built up the Zaribo MK3 clone printer based SKR V1.3 motherboard of TMC2130 drivers.Early on , printer has worked silently.But now , stepper motor in z-axis get noise like the spacecraft sounds.I set up the current of TMC2130 between min and max.When setting min current , motors don't get noise but when ? motion step motor cable with my hand , motor doesn't move to neither left nor right.If being max current was ,it went from bad to worse.
06-26-2020, 07:21 AM #2
learn to like the noise :-)
I think it sounds like r2d2 talking to himself :-)
Or adjust the voltage until the m,achine works and doesn't make any noise.
Holding the carriage is not a good idea. And under what circumstances is there going to the that kind of friction on the carriage movement ?
You don't need that kind of torque.
06-26-2020, 07:52 AM #3
- May 2018
- 566
I modeled and printed Ninjaflex isolators that go between the motor and frame and washers that go under the bolt heads.
07-07-2020, 08:52 PM #4
- Jul 2020
- 13
There are many ways to make the noise go away. Some work better than others. Just depends on how much you're willing to invest.
07-09-2020, 01:25 AM #5
- Jun 2020
how noisy is it
beginner in 3d printing. not knowning how noisy a 3d printer can be under normal working conditions. came across this online(see attached) the othe day. any good?
07-09-2020, 06:59 AM #6
- Jul 2020
- 13
I've never heard of them, so no way to know if they are good or not.
