10-12-2019, 09:26 PM #1
- Oct 2019
TRONXY XY-2 Cura Printer Settings
Hi all!
I am new to 3D printing and there is a ton to learn!
Cura was recommended to use as my slicing software. I have installed it, and of course my printer is not listed as an option. My printer is the TRONXY XY-2. It came with zero documentation and I am not sure what settings I shoudl use in Cura. I used what I thought was correct and tested a print. There seems to be an issue with the z-axis (up/down) since the nozzle starting position was a few mm above the bed. It doesn't seem that you can change a z-offset in Cura?
Hoping someone has this printer and help me ensure my settings are correct.
Thanks
Marc
