10-12-2019, 10:26 PM #1
- Oct 2019
- 2
TRONXY XY-2 Cura Printer Settings
Hi all!
I am new to 3D printing and there is a ton to learn!
Cura was recommended to use as my slicing software. I have installed it, and of course my printer is not listed as an option. My printer is the TRONXY XY-2. It came with zero documentation and I am not sure what settings I shoudl use in Cura. I used what I thought was correct and tested a print. There seems to be an issue with the z-axis (up/down) since the nozzle starting position was a few mm above the bed. It doesn't seem that you can change a z-offset in Cura?
Hoping someone has this printer and help me ensure my settings are correct.
Thanks
Marc
10-13-2019, 09:43 AM #2
You can change the 3D Printers Z-Offset using Cura M851 - XYZ Probe Offset in the Startup G-Code area.
10-14-2019, 11:16 PM #3
- Oct 2019
- 2
Thanks! So there is no way to set this in Cura prior to generating g-code? Or will I need to go into every g-code file and modify it? Also, I think I have a switch type probe and. I guess not sure how to determine this distance.
10-15-2019, 08:38 AM #4
Setting M851 - XYZ Probe Offset in te Cura Startup G-Code area.
In My version of Firmware can set the Z-Offset from the LCD display and save the settings.
Do not know what firmware you are using
Though you should be able to do a M503 this will tell you the current settings, I am using a Raspberry pi with OctoPrint installed.
As my 3D Printer is in a different room and not connected to my computer. Below is a sample of part of my M503.
You will note that the third line down is M851 and demotes my settings.
Please help, is this an Ender 3...
Yesterday, 12:56 PM in 3D Printers (Hardware)
