Results 11 to 12 of 12
04-22-2017, 01:21 PM #11
- Apr 2017
05-25-2017, 09:33 AM #12
well looking at the list of machines you have that are not working. Do you really want to go down the same route again ?
You don't seem to have a replicator clone.
So my advice would be to buy a couple of qidi tech rep pro clones: https://www.amazon.com/TECHNOLOGY-3D...ice+3d+printer
Seriously good machines, quality components, fully enclosed print volume and dual extrusion.
You can use them to fix the repraps you already have :-)
The makerbot replicator dual isn't one of the most copied machines in the world for no reason.
Extremely reliable, easy to use, fully independant of a pc - except for slicing :-)
And the pro version gives you heated build volume for using the more awkward filaments.
These machines are pure workhorses. Drop a sheet of printbite on the bed and you've got a tape,glue scraper free print surface that never needs replacing and should even withstand the rigours of a makerspace that obviously lacks 3d printer oriented users (or more of your machines would be running ;-)
Not autolevel - but pretty quick and easy to level. Just use the firmware's guided process.
Having just built myself a delta with repetierhost. I can't see how people manage without a decent firmware. repetier just displasy information.
Sailfish on the other hand turns the machine into a truly independant manufacturing system.Last edited by curious aardvark; 05-25-2017 at 09:45 AM.
