Page 349 of 411 FirstFirst ... 249299339347348349350351359399 ... LastLast
Results 3,481 to 3,490 of 4110
  1. #3481
    Where do you buy this one?
    It looks good that is for sure.
    Quote Originally Posted by Warren O'neill View Post
    i got some goodies in the mail today
    Editor in Chief
    Bitsonline
  2. #3482
    Looks very very interesting indeed.
    I would love one of those. I keep seeing things to upgrade on the printer and some that make me want to get second printer. LOL
    I like the idea of 4 at once. That would actually solve my issue of making a 3 color print with support. Could throw the support material on one and the other three are open for colors.
    The dual extrusion the QIDI is nice when using support material. Saves on cost with more expensive materials.
    Quote Originally Posted by wirlybird View Post
    Anyone read up on this yet? Looks interesting.
    http://shop.prusa3d.com/en/3d-printe...l-upgrade.html
    Editor in Chief
    Bitsonline
  3. #3483
    Engineer
    May 2016
    Location
    Annapolis, MD
    Very interesting. I am not clear on how the color change works. The "multiplexer" obviously handles the electrical split across the 4 extruder stepper motors. The video seems to suggest a massive filament retraction between colors, but I have to wonder what the previously "melted" end of the filament is like and how jams of that retracted and misshapen end would be prevented? Particularly when the distorted filament end must again be (re-) used.
    Also, does the height of the "waste tower" pace the height of the printed object? Is that parity maintained for filaments that are unused up to that point in the print?
  4. #3484
    Super Moderator
    Jun 2016
    Location
    Oklahoma
    Finally getting a chance to try Makergeeks clear PLA. So far it is print very nicely.
  5. #3485
    Super Moderator
    Jun 2016
    Location
    Oklahoma
    Quote Originally Posted by DaveB View Post
    Good questions.
  6. #3486
    Technician
    Sep 2016
    So, I will do another one with improved infill (it's disturbingly light), but I have to admit that the holes I'm getting up top are new. I've got seen that on any prints before.
    I would expect my "Top solid layers" setting in S3D to cover that, right? It's set to 4, which one would expect to be enough layers. Wouldn't it?
  7. #3487
    Technologist cncartist's Avatar
    Mar 2016
    Add cncartist on Thingiverse
    All installed and up and running it only took me 7 ours but that was with doing other stuff as well.
    Just a little bit of fine tuning to be done but that will have to wait until tomorrow.
    I wanted to take photo's so i could show how the install went but i got exited and didn't take any.
    Will post pictures of the finished install tomorrow.
    Nice, it's worked out well for me so far and I like not having to level the build plate so extensively after a long print.
    Quote Originally Posted by Merijeek View Post
    I use 7 top/bottom by default for all my prints and will go to 10 or 11 top/bottom to achieve water tight seals. 4 seems a little low and I would recommend bumping it up if it isn't a part which depends on tight tolerances.
  8. #3488
    Technician
    Sep 2016
    I'm not sure I've ever messed with it, so I'm assuming that it's the S3D defaults.
    I've finally got an ABS print that seems to be laying down correctly. Same thing, but in white. Will be interesting to see how it comes out. Of course I already had it at 4 layers...
  9. #3489
    Engineer
    May 2016
    Location
    Annapolis, MD
    I've used the MG PLA "Ah Natural (clear)" stuff. It has worked out fine for me.
  10. #3490
    Technician
    Sep 2016
    Unfortunately, the spool from our friends at QIDI was miswound, so it eventually hit a point where it wouldn't feed because it was bound up in the spool.
    Grr...
Tags for this Thread
