Results 3,481 to 3,490 of 4110
10-06-2016, 03:58 PM #3481
10-06-2016, 04:20 PM #3482
Looks very very interesting indeed.
I would love one of those. I keep seeing things to upgrade on the printer and some that make me want to get second printer. LOL
I like the idea of 4 at once. That would actually solve my issue of making a 3 color print with support. Could throw the support material on one and the other three are open for colors.
The dual extrusion the QIDI is nice when using support material. Saves on cost with more expensive materials.
Editor in Chief
Bitsonline
10-06-2016, 04:22 PM #3483
- May 2016
- Annapolis, MD
- 523
Very interesting. I am not clear on how the color change works. The "multiplexer" obviously handles the electrical split across the 4 extruder stepper motors. The video seems to suggest a massive filament retraction between colors, but I have to wonder what the previously "melted" end of the filament is like and how jams of that retracted and misshapen end would be prevented? Particularly when the distorted filament end must again be (re-) used.
Also, does the height of the "waste tower" pace the height of the printed object? Is that parity maintained for filaments that are unused up to that point in the print?
10-06-2016, 06:37 PM #3484
- Jun 2016
- Oklahoma
- 904
Finally getting a chance to try Makergeeks clear PLA. So far it is print very nicely.
10-06-2016, 06:37 PM #3485
- Jun 2016
- Oklahoma
- 904
10-06-2016, 07:02 PM #3486
- Sep 2016
- 80
So, I will do another one with improved infill (it's disturbingly light), but I have to admit that the holes I'm getting up top are new. I've got seen that on any prints before.
I would expect my "Top solid layers" setting in S3D to cover that, right? It's set to 4, which one would expect to be enough layers. Wouldn't it?
10-06-2016, 09:22 PM #3487
Nice, it's worked out well for me so far and I like not having to level the build plate so extensively after a long print.
I use 7 top/bottom by default for all my prints and will go to 10 or 11 top/bottom to achieve water tight seals. 4 seems a little low and I would recommend bumping it up if it isn't a part which depends on tight tolerances.
10-06-2016, 09:35 PM #3488
- Sep 2016
- 80
I'm not sure I've ever messed with it, so I'm assuming that it's the S3D defaults.
I've finally got an ABS print that seems to be laying down correctly. Same thing, but in white. Will be interesting to see how it comes out. Of course I already had it at 4 layers...
10-06-2016, 09:50 PM #3489
- May 2016
- Annapolis, MD
- 523
10-06-2016, 10:54 PM #3490
- Sep 2016
- 80
Unfortunately, the spool from our friends at QIDI was miswound, so it eventually hit a point where it wouldn't feed because it was bound up in the spool.
Grr...
