Results 2,961 to 2,970 of 4110
08-27-2016, 06:24 PM #2961
It's not a thermistor and it is 5mm threads. I have some extras if you need one.
08-27-2016, 06:29 PM #2962
Depends on the age of your Qidi last years model used the a smaller thread size this years is a larger thread.
I'm not sure of the thread sizes.
If you get new ones from Qidi also get new hot blocks to match. Not that much more.
Mine started out with the smaller ones but I've changed to the larger ones and matching hot blocks.
08-27-2016, 06:48 PM #2963
- Jun 2016
- Oklahoma
- 904
Thanks, these it turns out are 4mm. QIDI was quick to respond. The current one measures 3.8mm across the threads. The ones I have for the Tech-1 are bigger.
rcleav had a good idea. I don't know why I can't use one of the hot blocks from the Tech-1 for now. Any thoughts on that?
08-27-2016, 06:49 PM #2964
Threads are wrong size. Yes they did used to use 4mm, but changed to 5mm... I have some 4mm threaded ones also...
08-27-2016, 06:50 PM #2965
- Jun 2016
- Oklahoma
- 904
08-27-2016, 07:02 PM #2966
Odd they went back to 4mm on the new printer, hmm.
08-27-2016, 08:37 PM #2967
- Jun 2016
- Oklahoma
- 904
Ok, so I scavenged a hot block setup from the Tech-1 (used one) and replaced the one in the x-one and now we are back up and running. Seems to be working fine.
Now is the stress test for the computer - three printers running at once via USB and all doing great.
08-27-2016, 09:11 PM #2968
- May 2016
- Annapolis, MD
- 523
08-27-2016, 09:37 PM #2969
- Jun 2016
- Oklahoma
- 904
08-28-2016, 07:58 PM #2970
- May 2016
- Annapolis, MD
- 523
MakerGeeks is having a 20% off sale on all their filament, and everything on their website except Lulzbot. Free shipping as usual.
