Results 41 to 50 of 84
01-16-2016, 11:03 AM #41
think I have aflashair version 2 - it's nevel let me update or modify. So just being used as a slightly more expensive sd card.
It'd work in a camera - but bugger all use in a 3d printer. tried diffirent machine and operating systems - just won't let it's own setup software have access to the hidden linux setup.
Don't buy a version 2 - even if it's real cheap.
01-16-2016, 05:48 PM #42
Thanks for the help Mjolinor but I still get the same results I can only connect via wireless and not over my network. Maybe they changed settings/security in V3 cards.
01-17-2016, 10:19 AM #43
I'll Try and help..
You need to setup the card first through the Flashair utility. Once you get that correct then you need to open the CONFIG file and make the appropriate entries. I've used Notepad++ with out any problems, but make sure you use the USB safe remove system before removing the SD card from your computer. The Network keys must be set by the utility, so trying to add them to the CONFIG file wont work.
Here is a copy of my CONFIG,
CIPATH=/DCIM/100__TSB/FA000001.JPG
APPMODE=6
UPLOAD=1
UPDIR=/files/
APPNAME=3DPrint
APPNETWORKKEY=********************
VERSION=FA9CAW3AW3.00.00
CID=THIS WILL BE UNIQUE TO YOUR CARD
PRODUCT=FlashAir
VENDOR=TOSHIBA
APPSSID=GBSV2
LOCK=1
DNSMODE=1
BRGSSID=GBSV2
BRGNETWORKKEY=********************
APPAUTOTIME=180000
DHCP_Enabled=NO
IP_Address=192.168.1.14
Subnet_Mask=255.255.255.0
Default_Gateway=192.168.1.1
Preferred_DNS_Server=192.168.1.1
NOISE_CANCEL=2
WEBDEV=2
01-17-2016, 12:16 PM #44
That is how I set the card up with the utility then add to the config using notepad++.
[Vendor]
APPMODE=6
CID=02544d535731364731d8b8607900f601
PRODUCT=FlashAir
VENDOR=TOSHIBA
APPSSID=beerdart
LOCK=1
DNSMODE=1
BRGSSID=beerdart
APPAUTOTIME=1800000
WEBDAV=2
TIMEZONE=-20
01-17-2016, 12:42 PM #45
Look closely at my CONFIG file, you have entries missing in yours. The big one, right off the bat is UPLOAD=1.
One thing I've noticed with getting this card setup, there is no room for any errors. One mistake and setup fails. The good news is, once you get it setup, it works well.
01-17-2016, 01:31 PM #46
Sorry I posted the wrong config. Here is the one that is on the card now and only working over WiFi direct and not through the router.
[Vendor]
APPMODE=6
PRODUCT=FlashAir
VENDOR=TOSHIBA
WEBDAV=1
TIMEZONE=-20
APPSSID=flashair
LOCK=1
UPLOAD=1
DNSMODE=1
BRGSSID=beerdart
APPAUTOTIME=0
MASTERCODE=brewer123456
NOISE_CANCEL=2
01-17-2016, 01:47 PM #47
The problem is even in stock form the card will not connect to my home network.
01-17-2016, 04:21 PM #48
So after you have performed an "initialization" and setup the wifi, you still can't navigate to http://THECARDSIPADDRESS/upload.cgi ?
PS: You CONFIG file is still wrong, but I guess at this point you need to get it connected to your network first.
01-17-2016, 05:43 PM #49
- Burnley, UK
- 1,662
Hmm, been checking the flashair-developers website. All the information is now on there. When I did mine there was nothing on there about station mode or anything llike that.
Interestingly there is still no mention of setting static IPs in the config file even though you can do it.
01-17-2016, 05:46 PM #50
